Posted 7/5/2011 10:01 (#1849472 - in reply to #1848764) Subject: Re: sms products by field
Missouri
nei is correct they added this button a few versions ago and it essentially does what the going in and adding each product does but it is a lot simpler. You go into the edit screen and you have to highlight the total applied line then it will allow you to check the box down below. Good luck!
