Why is it when the border or headlands of a field pinches in 2 like in the picture below the A-B line will not be available on the other side of the field? I know i could just set a new ab after the headland is complete but that is one less pass that is auto steered. Also if the last pass is less than 1/2 of a swath width inside of the headlands then no swath for the last pass appears at all. although I am just using this setup to spray makes me wonder how it would be possible to ever plant with no markers. Or do I just have some settings wrong? Had another field today that almost pinched in two and the second headland appeared as a little tiny red circle right where the first headland almsot touched and that was it. So after doing the 2nd headland i had one swathpath appear that went thru that circle so had to make a new AB line in order to do the rest of the field.
(0628111924.jpg)
Attachments ---------------- 0628111924.jpg (51KB - 38 downloads)
