Anamoose, ND | I have a 07 Apache AS1010 with the Raven Autoboom leveling system. For the first year that I had the sprayer the Autoboom worked perfectly. This spring when I first used the sprayer I could not get it to work right. I got the manual out and read how to calibrate it. I went through the calibration process and I had it working OK. Then the next day when I went to use it I could not get it to work right. This has gone on all spring. I will start spraying in the morning and it won't work, so I adjust on the calibration screws for awhile then all of a sudden it will come back to life and work OK for the rest of the day. Even though I can get it working it never seems to work as good as it did when I first got the sprayer. Anyone have this problem? What should I check first? Thanks. | |
