Cedar Rapids, Iowa | ...something about the ports using RS232-C style comm ports...
I don't know what that means. It might mean the serial port pin-out is DCE (the other option is DTE), in which case you might need a null modem cable to make it work. Transmit and receive are almost always pins 2 and 3, but they can be flopped depending on the device and cables. Is that tablet's pin-out documented anywhere? |
