Western New York | I actually just did this! Ther is a cable that turns a dickey john radar connector to a triangle deutsch ground speed connector on the tee jet harness. what do you have a pull behind sprayer or are you running something else? Look for that triangle connector on the harness, then get back to me I can help! A pull type sprayer the triangle connector will be down towards that left wheel of the sprayer chassis as it is intended to plug into a radar. Let me know if this helps and email me I just so happen to have the parts! | |
