| There is more factors that play a part in swath then just timimg first you want to check your offset on your implement page make sure A and B off( A+B seed drop point ) sets are correct. Then your speed entering and exiting your headland needs to be consistant. A good starting point on your timming would be 1.7 for your on time and .7 for off remember these are lead times so on time at 1.7 is going to turn your plantter on 1.7 before you come out of the covrage and off time at .7 will shut off the plannter .7 before you hit the covrage. These numbers have worked well for me in the pastand speed is going to play a big part in tunning it in | |
