NW Iowa | I never checked it for voltage. In the diagnostics screen, I was watching for flow. I'm running a Raven proximity sensor (the EZ-Boom was designed so it could be used as a lone controller on a Raven system) sensing off of two lugs welded to a sprocket on the hydraulic motor used only to give me shaft speed. I found a calibration number that was showing me 7 gpm in the diagnostics screen at the shaft speed I needed. That equated to the same as spraying at a 20 gpa rate. I was using 20 gpa for Rate 1 and 2 as a starting point. | |
