NEND | That's certainly another way to accomplish the same thing, but I think he wanted to have it done before he went to the field, maybe not. Another way in Apex is to note the heading of the line you want to copy, bring up a map (boundary, application, yield map, etc.), click on create, then create a guidance line with the same heading. If you plan on shifting it in the field anyway, this would probably be the quickest. The way I mentioned in the first post will create an exact copy of the first line, no other way in Apex to do that. I wish there was a way to create one with an exact offset to the original, or be able to shift it in Apex an exact amount (like you can on the GS2). Then I could make one A/B line along each edge of my fields and create how ever many lines I wanted at specific offsets for various operations. | |
