Manitoba, Canada | Was trying to create some new guidance lines in AFS for the pro 600/700s because all my current guidance lines are using the greenstar heading system.
In afs i used the create guidance pattern wizzard which asks what the swath width is and how many headland passes you want which i found kinda neat. Go to export it to the card to put in the pro 600 and it gives me the error saying the display dosnt support multiple guidance lines and that i need to split them. I assume it needs to view the headland passes as a "curve" pattern? How do i split the patterns so i can import into pro 600.
here's the error and in the background what the guidance lines look like.
Edit: It appears even if I create with 0 headland passes it still gives me the error that it wont allow multiple guidance lines.
Edited by nevinstobbe 6/10/2011 13:59
(screenshotafs.jpg)
Attachments ---------------- screenshotafs.jpg (50KB - 50 downloads)
