roaming | Did you specifically select the guidance lines during the Device Setup Utility process? You must select the Year where the lines are stored in the Management Tree, and then select "Guidance", and then add the item to the righthand window.
Once you have the lines on the card (the software will create a new CN1 folder, so if there is already a CN1 folder on the card, you must delete it first), then take the card to the display and insert it before powering up the display. The display will automatically load the lines and they will be available for selection using the Swath Select window. | |
