South Central South Dakota | Just wanted to give a update used the john deere universal cab mount you use on the 30-55 series tractors to mount globe and used the center cab bolts. Mounted the the atu and used the 50 sereies steering wheel mount with alittle work it can be put on over the plastic collar so you dont have to dismantel it or cut it up. I mounted a brown box off the display that is there already. Wireing harness wise i drilled a hole and routed it behind the radio then went out by the mirror mount. Otherwise you woyld have to rub it through the door. Anything else just ask |
