| I have two 8430Ts with the newer version of software in the SST. I thought that someone had posted they had better luck with the older version when using autosteer. Both of these tractors are running Autofarm A5 systems and have trouble holding a line. Also was wandering about how high the deadband settings should be manually adjusted up after tractor calibration to make the tractor more responsive. Have the manual gain setting on the tractor set at 250. Open to any advise or things to try. | |
