| What type of setup are you using? an Inline servo works best if you reverse the the wires to the control valve and set the the 500 to bypass servo. The pressure will increase quicker and decrease slower as well as open when master shut off instead of closing. You could increase the overlap or change the valve thresholds. Valve latency should be set to 0 or no more than half of what it should be if you want the screen paint to match what is happening on the ground and overlap increased to make sure you get complete coverage. | |
