Near Intersection of I-35 & I-90 Southern Mn. | Just think of it like this: The GS2 will send over the Rx rate to the Rate 1 register as if you had typed it in yourself on the Raven keypad. The Raven will attempt to apply Rate 1, Rate 2 or Manual just like before depending on the position of the Rate1/Rate2/Manual switch.
This means that you can take control away from the Rx prescription if you want to by switching to Rate 2 or Manual. The actual applied rate computed by the Raven will be sent back to the other device for recording/mapping purposes. This means that the map created will correctly reflect the actual application situation. |
