NW Central Iowa (Fort Dodge) | The problem I think with the Strip till module is it would always beep "Rate Not Responding" Becuase Ag Leader is not controlling anything.
What we did on our 1250 is remove the ER4 and installed a App Rate Module, told the Display that we are monitoring a Flow meter. In the setup put 2 pulses per revolution and make a application product called Bulk RPM and your done. As far as the seed tanks, we just figure when we run out we run out and get more seed. You need a multiproduct unlock to make this happen. |
