| Yep. Adaptive curve is the way to go. It took me a little bit to figure it out when I first tried it. Let's say you started by doing the headlands with adaptive curve, then you do your AB line for part of the field and realize you have to make some additions to your headland passes and you go back to adaptive curve mode. When you go to that mode it will come up with a screen saying yes or no. Say no. I don't remember the message on that screen exactly but if you say yes, you will only be able use autotrac on passes that you've already driven previously. If you say no, it will create new lines based on your old lines which means that you'll be able to use auto-trac in new areas. | |
