Posted 5/26/2011 14:39 (#1793121 - in reply to #1793094) Subject: Re: Need help with Insight with Topcon receiver
Clatonia, NE
You may need to put in a 2.5' offset in the Insight to opposite side you want to push you're pattern. For example, if you're consistently overlapping on the left side 5 feet, you need to put a 2.5' implement offset in to the right side. That's only if it is a consistently on the same side and the same width. Good luck!
