roaming | your dealer is correct. To use the Pro 600 Lightbar Mode, you do not need a NavII controller. However, without one, you won't get terrain compensation. Depending on what you're doing in the field, that might be ok or not. If you decide to spend the money to get a NavII for terrain compensation, you might as well go all the way to full autoguidance...
To create a new AB line, simply use the Swath Record window that you can place on any Run Screen. You can choose the type of swath you want and name it whatever you want, then drive the line to record it.
If you have multiple swaths in a field, use the Swath Select window to choose the one you want to use. | |
