Posted 5/18/2011 09:32 (#1780318 - in reply to #1780210) Subject: RE: ISO Issue with Greenstar 8295RT Disable Implement Can
Texas Panhandle
I believe you go into menu, display, setup (arrow and dot), then go to the button with the two displays and make sure the implement bus box does not have a check and is inactive.
