South Central Kansas, Harper County | I had a similar problem last year in my JD 8770 tractor. My Brother was planting with my air seeder, and, although it wasnt as drastic as yours, it was still off a bit. I got in and played with settings, kept getting out and measuring, and still couldnt get it corrected satisfactorily. I called Outback, and they kept suggesting adjustments, but nothing worked. UNTIL, I looked down at the E-drive and it was cocked to the side. I remembered I had taken it out and placed in my other tractor earlier in the spring, as that E-drive was sent in for repairs. I apparently had just put it back on the floor of the cab in the corner, not thinking about direction. Anyway, once I adjusted the E-drive location, my lines were as straight as normal. Hopefully, your "fix" could be as simple as mine? Good Luck |
