A RTK Paradyme WITH a 900 radio and Glonass unlock is $18,000. Then add the Integra and what every tractor kit you need. You can use the Integra and the trimble antennas but that only leaves you with the Ontrac 2 to steer with. You need the Paradyme with the Integra in order to use the hyd steering block. there are kits to use a Paradyme with a Trimble hyd valve. Sounds like you have some bad info or understanding of the equipment. You need to find a dealer that will lay it all out the right way. I am not convinced peiceing together a system is the best and cheapest solution. |
