Near Intersection of I-35 & I-90 Southern Mn. | Pin 2 of the Port Connector should go to Pin 2 of the AMP connector on the 250 monitor. Pin 10 (Ground) should go to Pin 1 of the AMP connector. You do not need connections to Pin 3 (Power out from the 250) nor Pin 4 (not used on a 250).
I'm not familiar with the setup on the FMX but I assume it is similar to that on a 750 where there is a menu item pertaining to the Radar Out. With a 750, I believe this is only possible on Port A but an FMX might be different.
If you set the output to around 59 HZ, then the speed cal of 7836 which is often used with a 250 should be close. Once you get action you can change either value to get the speed of the 250 to match the FMX. |
