Posted 5/14/2011 09:24 (#1773909 - in reply to #1772509) Subject: Re: JD 8030T with Autofarm A5 steering drift
To add to averagejoe’s comments, make sure to turn off your AutoFarm system when you do the manual steering test. If your tractor steers straight manually you should recalibrate the AutoFarm system, however during the steering wheel calibration press down the blue button on the display. Good Luck
