Posted 5/13/2011 07:40 (#1772216 - in reply to #1772209) Subject: Re: Envizio Pro question/problem
Butterfield, MN
Boom switches off and foot switch turned on. Make sure you connect the switched side, not the constant power side, of the foot switch over the the sense wire on the Envizio Pro sense wire, and select that in the control interface screen, not the AccuBoom sense wire.
