Winkler, Manitoba Canada | The Raven smartrax valve might work directly with the Trimble Nav 2 but you would need to change a few things. You would need to substitue a Trimble steering overide pressure transducer for the Raven switch arrangement. You would also need to adapt the Raven steering position senser if the sprayer has one or more simply add a Trimble steering position sensor or autosense. Then you would need to modify the electrical harness or purchase a new one. Probably could all be done if one is so inclined but no guarantees! | |
