Butterfield, MN | 135 is back going, so that`s probably not the issue. you should be able to go in through the lightbar and make sure the PRN didn't default back to 122 or something silly like that. Also, check the simple stuff, make sure you are still getting power and ground to the 115. check the fuse on the antenna cable, and double check to see if you get power and ground between the two pins counter-clockwise from the keyway on the plug on the cable for the antenna. | |
