NW Iowa | I'm using an EZBoom to control a pwm valve on the planter. I should say trying to. I keep getting a "No EZBoom Comm" message on the FMD display whenever I change anything. I've got a steady green light on the EZBoom. Can vary the rate from the FMD when set on manual. Won't control anything when set to rate 1 or rate 2. My shaft speed sensor is working properly and I'm showing varying shaft speed when adjusting on "manual". I've tried shutting down both and powering them up together numerous times. Did my EZBoom crap out or is there something else I need to try?? TIA
Edited by bushed52 5/9/2011 08:07
