Posted 5/8/2011 14:46 (#1765878 - in reply to #1765768) Subject: Re: EZ-steer and 500 is not moving over the right width
mn
sounds like your antenna needs to be offset a little. if you spacing is correct. just tite on one side and wide on the other it sounds like you need to adjust you antenna offset TOWARDs the wide side.
good luck
