Posted 5/9/2011 17:00 (#1767514 - in reply to #1765238) Subject: Re: Trimble FM-1000 "rate as section"
Francesville, IN
<p>that means you are going to use your rate controller as a section controller for instance if you are tying into PWM Drives on your planter you can use those PWM drives to shut off the sections that they are controlling when they come into a planter area. (Cool feature that AgLeader can't do)</p>
