Posted 5/9/2011 23:54 (#1768068 - in reply to #1764690) Subject: Re: FMX and JD 1770NT vacuum readings
Did you try going into the setup onder system? I believe there is a way to edit the run screen and select Items for the status slide out an the info tab. If i recall right there is a list of parameters that you can select from that includes FIQ and customize both of these screens...
