Edwall, Wa | You have to disconnect the ez-boom from the 500. If you have ez-steer disconnect the Y cable on the ez-boom & reconnect the the 500 to ez-steer. If you have Auto pilot just disconnect from the 500 power cable. Also make sure you save your configuration so next time you hook up ez-boom you can load the config with all your settings saved.
Wrench
Data Management
Save Load Configurations
Save current config
Save to USB or internal memory
Name saved config
When you want to use ez-boom again reconnect it and load your saved config.
Wrench
Data Management
Load a Configuration
Select Config you named for ez-boom use | |
