Used Acronis to clone the drive. It put C on the new drive as G and the hidden D drive as F. I then used the WD program to clone the drive and it did the same thing. I used Disk Management to switch F to G and G to F but I can't make F which will be C a Primary partition, it remains a logical drive. I can't see a way to change that. I've cloned a lot of drives and never had this problem before. It's an XP system on another HP computer. When I disconnect the cable from the old C drive and put it on the new drive it will not boot. All the files are there and the computer see's the drive, until I disconnect the original drive then it doesn't see the new drive.
