Lapel, In | 4-1/2" capscrews (3/4" socket)to remove and the hydraulic oil line directly behind the seat.Pull the cover off.Lift one of the arms up, push the piston back in and slam the lift arm down. The piston should pop out enough to get a hold of it. Check the bore for scoring. Replace the o-ring and back up washer and reassemble.Its usually an easy fix,.
If that doesn't fix it, you may have to reseat the thermal relief valve.
I just use a short chain to hold the arms up. | |
