....found an acorn. After downloading and installing a program to try and read the card I was required to restart the computer. When the computer came back up it was checking drive status and found the PC card slot with the corrupted CF card in it and automatically fixed the error(s) on the card. I can now read the card and all data unloaded successfully! I haven't determined if anything was lost yet but certainly almost all of it is OK. What a deal! Thanks to everyone for the help. BTW there is a hidden folder on the card now labelled FOUND.000 containing 4 files titled FILE0000.CHK through FILE0003.CHK of type recovered file fragments and a .txt file with this: Checking file system on D: The type of the file system is FAT. Read failure with status 0xc0000185 at offset 0x10000 for 0x10000 bytes. Read failure with status 0xc00000a2 at offset 0x10200 for 0xea00 bytes. An error occurred while reading the file allocation table (FAT 1). One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. Windows will now check the disk. Volume Serial Number is 3B69-1AFD Read failure with status 0xc00000a2 at offset 0x4811600 for 0x8000 bytes. Read failure with status 0xc00000a2 at offset 0x4811600 for 0x8000 bytes. Folder \RCD\StoredMaps\fee64f2f-d704-47ca-9f08-6d0d222611b8\f61689a7-81c7-4454-a5bc-98d22b3c4131 is entirely unreadable. Folder entry removed. Convert lost chains to files (Y/N)? Yes 327680 bytes in 4 recovered files. Windows has made corrections to the file system.
2047541248 bytes total disk space. 32768 bytes in 1 hidden files. 5242880 bytes in 160 folders. 88506368 bytes in 2082 files. 32768 bytes in bad sectors. 1953726464 bytes available on disk. 32768 bytes in each allocation unit. 62486 total allocation units on disk. 59623 allocation units available on disk.
Edited by KevinM 7/3/2010 17:21
