| I think you are doing it the best way to eliminate gaps but my understanding is this. When you lower the planter while stopped you will see the QS reset button countdown from 6 seconds if you don't take off then it times out and you have to reset it. If you stop and leave the planter in the ground, you get ready to take off and hit the QS reset and it is again active for 6 second I may be wrong but I don't see much difference when its active or not. Our case 1200 had a prime button that spun the meters for 3 seconds so you could hit that at the same time you took off and it worked pretty good. | |
