| I am not familiar with the 9400 but have a 9600. I think you are talking about the double pulley on the engine gear case above the unloading auger shieve and this pulley also does drive the chopper. If this is what you are talking about, the zerk is in the center of the pulley between the two belt grooves. The pulley has to be turned just right to see it, so just go around the complete 360 degrees and you will find it. Hope this helps. | |
