Ashburn, GA, (very close to Heaven!) | Copy the files from the yield card to a folder on your hard drive FIRST. Then see if they will import into Farmworks. I maintain a folder for every grower, then subfolders by crop and year, for example.
You will have a backup of your raw data this way, great advantage if you are needing to exchange information to different GIS applications. The actual time for COPY plus IMPORT will probably be the same as DIRECT IMPORT. |
