Search Forums | Classifieds (46) | Skins | Language
How do I delete data in Operations Center?
rhrentz
Posted 4/27/2024 06:09 (#10719676)
Subject: How do I delete data in Operations Center?
South Carolina
Let's say you are recording your field work using the 3 point hitch to start/stop mapping
You finish the field and drive 2 miles home, park the tractor, and let the hitch down.
Later you look on OC for that operation and find the field correct but showing a very tiny acreage recorded where you parked
This makes for a hard to see map because of the large 2 mile gap
In Apex I could zoom in put a polygon around that tiny area and then delete it
When I tried same process in OC it deleted the whole field
What did I do wrong?
