Posted 5/4/2024 10:56 (#10728366 - in reply to #10718803) Subject: RE: replacing 460 raven controller with an ez boom
If anyone else has this issue, the answer is yes. the diode jumper lets the EZ Boom in control. You just shut off the factory switches on the arm rest and you do not use the on-off switch on the SR lever. You program the EZ Boom to NO fence line nozzle, but you have to turn the switch on the SR lever to on to make the factory fence line nozzle switch to work.
