| New to us planter. Equipped with one vacuum fan, delta force, hydraulic drive alternator for v drives, and bulk fill. Tractor is a Massey Ferguson 8480 ( new to us also)with four remote valves and a power beyond. Had it all hooked up as follows. Delta force/alternator on power beyond. #1 lift, #2 markers, #3 vac fan, #4 bulk fill. With everything running the lift is pretty slow. Thinking we will need a PTO pump to run one of the fans. I would like to keep the vac fan on the tractor for ease of adjustments when necessary. Some insight on this would be greatly appreciated. Thanks | |
