NECIL | We swapped cables and got it down to the load cells on the left side. The guy at Clark my uncle talked to was pretty sure it was just a bad cable. We swapped the cable and it worked. $100 cable is better than the $1200 load bar and the work it would entail to swap it. Only thing now is when we zero the scale it always says -190. Can’t get it to true zero. But it works for now and weights are pretty accurate as we unload. | |
