| I have 2230, 2330 and 2660 that I would like to put on a Case Quad. Can I order 1 Add on valve and install it on the tractor to use on all 3 tools? My plan was to make an extension harness from the valve to the truset trunk harness and make custom shorter hoses feeding the valve Pressure/Return. My plan was to order the 1 port valve for the 2230 so the Up/down circuit would be AUX/Auto and then the rest of the functions on the tools I would control manually. The biggest question would be if I have my dealer flash software to the Valve controller as a 2230 will it work with my 2330 and 2660? Thank you very much for your help. | |
