Central Kansas | I don't have any experience with a two line wet kit, but I think they are setup to run a hydraulic motor ( such as a pump or your floor chain), and the oil is constantly recirculating. It doesn't take as much oil in the reservoir for this type of setup. For an end dump with a single line the oil is pushing the cylinder up and it takes a lot of oil to fill those cylinders. The truck we use on our end dump has probably a 30-40 gallon reservoir. You might take a look at yours and make sure it has enough oil capacity. | |
