| Serial cable with 12V on pin 9 and Parani Senna SD1000 BT-serial dongle and Android phone / tablet with Lefebure NTRIP Client is a working system.
On an EZ-Guide 500 you can connect Senna directly to D9 connector of the display if you don't use other functions of that connector (coverage logging or radar speed output).
On the 372 you have to use a cable. I once had a 252 with bt-serial. It was connected to Port 3 on plug B. (right side one) As far as I know ther connections on 372 are the same.
See picture taken before heat shrinking the cables:
Edited by Artic 4/4/2024 15:04
(IMG_20151010_151135 (1) (full).jpg)
Attachments ---------------- IMG_20151010_151135 (1) (full).jpg (70KB - 7 downloads)
