Search Forums | Classifieds (76) | Skins | Language
JD5020 Hydraulics
ccjersey
Posted 3/28/2024 13:31 (#10684277 - in reply to #10684249)
Subject: RE: 5020 Hydraulics
Faunsdale, AL
2000-ish would be what I set. The setting adjustment screw is on the bottom of the bore on the front pump that the destroking screw goes in the top of.
Left front corner of the pump. Bore is vertical with a jamb nut on the adjusting screw in the bottom. Top may be plugged with an O-ring boss hex head plug or may have a destroking screw jinstalled already for starting in cold weather etc. It can be a t handle screw or some are a small hex bolt you run down with a wrench to destroke it. With engine idling you’ll normally hear the pump change its noise when it quits and starts back up as you back the screw back out.
Edited by ccjersey 3/28/2024 13:46
