Early riser 900 planter marker problem
tj_farms
Posted 5/5/2016 23:07 (#5285134 - in reply to #5284987)
Subject: RE: Early riser 900 planter marker problem
Ohio
Mine did that when the pivot points on the folding hinge pins got dry, rusty and galled. oil usually fixed them. Also if yours has the chains for the outer wings, they may be too tight, need to flop around a little.
