| Anybody running there tri axle lowboy with 3rd axle lift to CA and getting bothered? I’ve ran cali alot but never wide and with a tri axe. I no 53’ pots spreads up to 4 axles ive seen running around. But we cant exactly go around the scales with permits. I talked to CA about a permit and from i gathered there is no available permit for a 53’. Just needs to meet the 40’ kingpin law. Only for special trailers/loads that can only be moved by those unique axle setups can be issued a over-length permit. If you no otherwise please shed some light. Thank you! | |
