Hiawatha, KS | You may want to try going to Settings>GPS Settings>SBAS Settings and switch SBAS 1, 2, and 3 from Auto to 138. This will allow the Rebel to concentrate on one satellite signal instead of the several it can rotate through on Auto. It can grab one signal one way down the field and another on the way back causing the shift in your line. For more information, contact your nearest dealer or call 1-800-247-3808, Mon-Fri, 8am-5pm CDT and one of our Customer Support/Tech Support Specialists would gladly assist you. | |
