Search Forums | Classifieds (150) | Skins | Language
Hand valve for Emerson air jack
   Forums List -> Where Can I find?????Message format
TP from Central PA
Posted 5/13/2021 15:43 (#9003570 - in reply to #9002674)
Subject: RE: Hand valve for Emerson air jack
My pair had those and they were bent, leaked, and didn't work well.........................I made a Tee with two ball valves. I have them on a small plate that sits or you can hold it, can run each valve to lift things even, and then if you want to come down you can pull the pressure hose off and use them to drop it evenly. Works good for me and I am sure tons cheaper than Emerson would have wanted for the factory one.
