Posted 5/10/2021 16:31 (#8998203 - in reply to #8994945) Subject: RE: post pattern tile spring prep work
Farmington IL
I go out as early as possible in the spring and straddle the trench with a small mounted chisel not very deep. Then if it is going to beans I might chisel the field on a angle that lets me cross the runs at an angle. If going to corn I just run along side with a cultivator then plant. They will settle for 3-4 years.
